Home > Help Needed / General Tech Chat > Fuel regulator
nobbie
Member #: 162
I have read that you need to install a fuel regulator when running a metro turbo engine, Is this the case?
If so i know you have to run a return to the tank, does this mean i will have to drill and weld in an adaptor to the tank, or is there something to conect the return to the tank already in place.
please can you help.
1310turbo
Member #: 41
yes mate, you will need a regulator. you can buy these new from many mini centers such as mini speed. it allows more fuel through as the boost pressure increases. so you will need a line from the plenum to the regulator. a return to the tank (either weld in a small piece of tube or buy an MPI/SPI cooper tank, as in the presvious post to yours).
there is a diagram of the connections in the "How to" section.
hope this is of some help
p.s. you sometimes see them on ebay, or someone on here may have one they can sell to u
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
evolotion
Member #: 83
Glasgow, Scotland
Brand new there about ?50, came across them in the FSE catalogue at a local motorsports place.
Denis O'Brien.
nobbie
Member #: 162
cheers guys
