Home > Help Needed / General Tech Chat > T2 Turbo cooling
SurfToLiveLiveToSurf
Member #: 748
Cirencester, Gloucestershire
bit confused about how the water cooling works on the T2, used the search but couldnt find anything, cant use air and water cooling?
mark
1310 - Supercharged 16v Twin Cam - 190BHP - SC Built.
1293 - Turbo 16v Twin Cam - Build Commenced
Kean
Member #: 341
aka T2clubby
South Staffs
Not sure what you mean by air / water cooling but...
The T2 has two water connections to allow the turbo to be piped into the coolant system, thus reducing the operating temp.
Can you be more specific in what you mean?
Member #: 748
yea sorry, wasnt very clear just basically wondered how the water cooling works and how efficent it is, and is it still possibly to connect an intercooler as well as the water cooling?
mark
Kean
Member #: 341
aka T2clubby
South Staffs
Right, the water cooling is to help reduce the temp of the turbo unit.
Intercooling is to reduce the temp of the inlet charge after it has been compressed by the turbo.
2 totally different things mate, you dont have to run an intercooler but if you are running a higher than standard boost level it is very wise to do so.
Some t2 turbos dont have water connections... the earlier ones I believe..
Mine has water connections but I'm not bothering connecting it up.
Turbo life will be reduced, but not drastically. And if you change the oil regulally enough, lifespan shouldn't be affected at all.
Wil
Member #: 748
yea, i understant now cheers guys, bit of a basic question but just wanted to clarify how it worked.
SumpNut
Member #: 28
Yea its mainly aimed at factory produced cars that are expected to go forever on no services.
By keeping that core a bit cooler helps to increase service life of your turbo. Maybe worth doing if you intend to keep the turbo long term - but you could probably leave it.
Mine is hooked up - it was easy and made no noticable difference to my engines running temps.
Member #: 748
yea, thanks for help again, will do that then, anything that helps reliability is good in my book!
Mark
