Home > Help Needed / General Tech Chat > Brake question
t3gav
Member #: 229
Gavin@minispares.com
kent
bit hard to explain but here goes, on the front subframe drivers side there is a banjo bolt that goes into the subframe directly into the brake caliper hose, on mine i had to cut it down as it was too long is this right? anyone else had any problems? i'm converting to cooper s calipers soon so do i just need the new hoses from the caliper (obviously i will need the flanges etc) enable to bleed the brakes? cheers gav
Just found the exact same problem with mine. Which is weird as it fitted fine on the old braides hoses which should have been the same.
I trimmed the Banjo bolt a few threads, seems fine.
Wil
nogin
Member #: 487
westbury, wiltshire
same here
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
