Home > Help Needed / General Tech Chat > rear brake adjusters
TURBO ME
Member #: 772
new york
best way to remove frozen rear brake adjusters?
Heat, penetrating oil.
Sometimes welding a larger nut to the square drive can give you a bit more leverage to get them moving.
Be warned though in some instances they just will NOT be moved, if that is the case you may need to find a better set of backplates.
