Home > FAQ / Knowledge > Sparkplugs
Kean
Member #: 341
aka T2clubby
South Staffs
Was doing some reading and found this.
http://www.ngksparkplugs.ca/tech_spoverview.cfm
Really usefull if you dont know much about plugs.
jufferb
Member #: 775
stourport-on-severn, worcestershire
usefull info. i have used ngk on my other cars. i didn't really think much into spark plugs. in the bible it says by fitting a wrong tempreatur plug can loose as much as 20 bhp !!!! has any body used the DENSO IRIDIUM plugs? they were desighned for turbos to stop the spark blowing out at high boost.
If in Doubt, go flat out !!!
Carl
Member #: 95
liverpool-on-sea
dont know if iridium plugs were designed for turbo use as toyota use them in some of there boggo engines. *smiley*
