Home > Help Needed / General Tech Chat > Can I Turbo???
Skinns46
Member #: 165
Cambridge
I've just got hold of a standard 1275 mg metro engine. I've also got a T3 turbo and manifold.
Can i fit and run the turbo without lowering the compression or any head mods?
I understand all the other mods that need to be done.
This is just till funds grow and i can buy a set of pistons.
Thanks
Roland
http://photobucket.com/albums/y139/Skinns46/
evolotion
Member #: 83
Glasgow, Scotland
yep, i thin.. youl need the rest of the turbo bits, and you wil need to keep the boost to <7psi.
asumeing its not a high compression engine like the MG.
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
shite.. jsut saw you have an MG engine, quite sure these run a higher CR..
you could always run the wastegate at standard settings which will show 4PSI of boost.
Denis O'Brien.
Normally aspirated MG Metro has a compression of 10.5-1, which is to high to run any real boost. Why not lower the compression by enlarging the chambers in the head, instead of buying pistons ? Then Turbo it.
Phil. *smiley*
Skinns46
Member #: 165
Cambridge
Cheers guys.
Oh of course the head. Do i need to take it to a machine shop to get this done?
Do you have any idea how much to take out? (final CC in the head)
Could i also use a thicker gasket or is this a bit 'bodge'
No you can do it yourself it's relatively easy. How much you remove depends on what compression ratio your aiming for ?
I've heard of people using 2 head gaskets, but couldn't comment on its reliability.
Phil. *smiley*
Skinns46
Member #: 165
Cambridge
Ok ok,
Do you think a 'black & decker' multi-tool would do the job?
If not What would you recomend?
thx
ro
Skinns46
Member #: 165
Cambridge
Ok ok,
thx
ro
not for the amount of mateial you want out of the head...
Have a work with minimark. i think he might be able to sort a head to your requirements...
minimark
Member #: 19
newcastle
minimark@blueyonder.co.uk
