Home > Help Needed / General Tech Chat > turbos
jufferb
Member #: 775
stourport-on-severn, worcestershire
bit of a silly question, i have search to no luck. can you use a deisel turbo unit?
If in Doubt, go flat out !!!
Mirage
Member #: 119
You can but life will be shorter than a petrol unit. The material specs are different for the turbines.
A friend of mine {Mike} has been using Turbos from various diesels on his Mini sucessfully for years. Granted he doesn't cover a huge mileage, but they can be picked up for bog all at the scrappy so a couple of years use for £10 sounds like good value to me.
Phil.
nutter driver
Member #: 47
Not very sunny swanage
just echoing what has already been said.... may not be the best choice for long life, but works fine.... probably wouldnt buy a diesel turbo if i was buying a brand new one, but for the sort of life we expect anything to have, and given theyre availibility, they seem more than suitable....
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
sorry , t2's diesel turbos are top of the choice for minis,yu'll find plenty, and you can punish them with very high boost, they 'll give you plenty of happyness, about their life, all yoiur engine will be out before your turbo
KKK turbo on my 306 TD is currently running a shade over 1.5 bar quite happily. It is virtually identical in spec to a T2.
Its not too bad. The Spannerbitch Racing rear exhaust section mod (e.g. there isn't one) also made a big improvement.......
Dangerous
Member #: 417
On 23/03/2006 14:33:02 mini1071s said:
Inconel is inconel. Bloody hard :)
Not True there are differant grades such as Inconel 600, Inconel 800 the number being the temperature it anneals at*wink*
