| Home > Technical Chat > turbo inlet and mirage manifolds | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
15th Mar, 2006 at 09:53:21pm
ive done some searches and it seems the turbo inlet is the one to use. ive put them both on a head and they foul by quite a bit. has anyone modified the turbo inlet to fit, and is it just a matter of grinding till it fits?
15th Mar, 2006 at 10:04:11pm
I machined about 4mm off my inlet manifold face to get them to sit right.
15th Mar, 2006 at 10:51:40pm
I believe that the mirage manifolds are intended to work with a NA MG Metro inlet manifold as opposed to the turbo inlet, which may be why it doesn't fit immediately.
15th Mar, 2006 at 10:59:41pm
Yes they designed them around the NA model because it is much easier to get hold of . |
16th Mar, 2006 at 08:59:23am
Mine fit spot on after filing the back of the flanges down to the same width. The more material you keep on the front of the inlet flange the better. i havent touched mine at all, just the two "ears" each side furtherest from the head if you get me. |
16th Mar, 2006 at 06:20:51pm
Mine fitted with no fowling and I use the turbo inlet.
16th Mar, 2006 at 06:25:49pm
On 16/03/2006 18:20:51 SumpNut said:
any difference between them will see leaking you must have special eyes |
16th Mar, 2006 at 06:47:40pm
lol |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
16th Mar, 2006 at 06:49:00pm
just worth mentioning i think that there is a fair amount of variation in the manufacturing of the mirage manifolds (and possibly the inlet?) so i guess some people do get away with it
16th Mar, 2006 at 06:58:03pm
yeah, we noticed that mine and dan's both fitted slightly differently. mine had clearance on the inlet whereas his didnt.
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
16th Mar, 2006 at 07:18:50pm
You pretty much got it covered there folks.
16th Mar, 2006 at 09:08:44pm
right then id better get the angle grinder out. cheers for the help everyone. I'll put the manifolds on a head and post up some pics so we know whereabouts it fouls
20th Mar, 2006 at 08:54:43pm
16th May, 2006 at 10:32:48pm
sorry to bring up an old thread, but im using a heated cooper inlet manifold and everything seems to fit right and looks ok, the only down side is the difficulty of undo-ing the two centre nuts from above. would it be easier to do with a NA manifold?
16th May, 2006 at 10:37:25pm
buy a 1/4 drive ratchet, long extention bar, some k nuts and a 10mm socket
16th May, 2006 at 10:45:13pm
Ahhh ok! I have K nuts but the ones i bought are M8 ones what do i order please? thankyou nic Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
16th May, 2006 at 10:59:27pm
5/16ths unf for the head studs
17th May, 2006 at 08:02:44pm
Thanks nic!!
19th May, 2006 at 11:44:04pm
you can also get silver k nuts, these are rated for higher temps, but cost more |
20th May, 2006 at 11:37:11am
Mine came, they are actually like a dark grey/silver colour i think it might be the high temp ones Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
20th May, 2006 at 11:37:37am
Pics of how much i machined off mine...
