Home > General Chat > cheers
to Jon who gave up his wednesday to help me build up my short block
couldent get it done due to a oversight on my part and my local motorfactor supplying the wrong bearings and an aftermarket vernier timing gear that just would not fit but jon still went out his way for me
hopfully by tuesday i can get the wrong and faulty parts replaced then get stuck into it again
Neil
Nicky
Member #: 333
Tadley, Hampshire
He's a goddun isn't he?
I was speaking to him wednesday too. He said you'd popped over. Cheers for dropping off the tyres *smiley*
I'm collecting at york all being well!
yep spent 3 + hrs on the vernier timing gears with a bit of emery in order to try and get the crap to fit
in the end had to call it a day, with the problems ive had with my back it was a great help
giallofly
Member #: 164
The Stig..
Newport Pagnell
Well it is in return for the spares you have sorted me out in the past....
There is always another day.
JF.
turbo hogster
Member #: 178
stowmaket suffolk
bit like your 4 pin diff wolfie i spent the best part of 1 1/2 hours just get the f@cking thing apart let alone rebuild it, also had to grind the old inner trace of the diff whell as that wouldnt bloody come off neather must be somthing to do with you wolfie old mate lol.
buy the way those sc gears are quality mate, better than the clubman set, at least you can a sutiable sized tool throught the whole to press in the plungers rather than using a peice of stainless steel wire.
This is the spirit of TM, keep it up lads!
Hoggy - What gears are they? The ST ones I'm guessing?
I agree - like the old days! *happy*
no mate new old stock tran x
but the 4 pin diff was brand new? in a sealed box?
