Home > Help Needed / General Tech Chat > supercharger
benfredjosh
Member #: 927
port talbot, south wales
just wondering does anyone here run a supercharger as this is the best forum for forced induction on a mini really???
so I was just wondering...
i knwo the commonly used supercharger for the mini is the eaton e45 or m45 cant remember? from the new bini! well just wondering anyone ever thought about using a different style one? i found this on on fleabay! it looks like a good shape to fit under the mini bonnet and the intake etc seem to be in a good position for the mini just tell me what you all think? as in how would i make up manifolds? what is the proccess? thanks!
Ben**
here is a good start for you.
http://www.vmaxscart.co.uk/
garethlloyd
Member #: 616
Birmingham
Think he is on minifinity too.
benfredjosh
Member #: 927
thanks all for your help HAs stu used this charger i am looking at?
benfredjosh
Member #: 927
thanks done !
turbochargedstu
Member #: 908
gateshead
that is an eaton m45 type blower, as found on the bini. the mercedes kompressor uses an eaton m62 which is a bit bigger still. they are simple design that you dont need to give it an oil feed because it is sealed at manufacture.
i'm running an eaton m90 as fitted to aston db7, lister storm, hummers ect ect. mine just fits under the bonnet with a little raising at the back so the bini and merc ones will fit easier.
if you wanna delve into the supercharger fitment ideas that are floating around in my bonce, then pm me
balls to the blower!!!
Dangerous
Member #: 417
1275_dan on here had a vmax convertion but I don't think he's on here any more
turbochargedstu
Member #: 908
gateshead
the v max conversions look a bit flimsy to me. the belts are really really long without idlers, which encourages slipping!!!
