| Home > Help Needed / General Tech Chat > OT- Diesel problems | |||||||
![]() 151 Posts Member #: 165 Advanced Member Cambridge |
23rd Mar, 2006 at 10:06:23am
23rd Mar, 2006 at 10:46:31am
The glow plugs reading 12v don't mean anything,You need to disconnect them and make sure they are all taking a current.My glowplugs usually only last a year.
23rd Mar, 2006 at 10:51:39am
Yes agree with Dangerous. Most conclusive way to test them is to remove them and then connect up 12v and earth to them. They should glow red hot within a couple of seconds. If they don't glow at all they are knackered, definately.
23rd Mar, 2006 at 11:08:26am
You really need to check the current draw of the glow plugs...
AlexF |
23rd Mar, 2006 at 11:58:46am
I just put the battery charger on each plug seperate,still in engine(with the links removed)take about 6 amps each
23rd Mar, 2006 at 12:19:02pm
Cheers guys. Right well i took all the plugs out-connected them all to earth and they glow red hot. (infact i started melting the rocker cover,oops). When it's warm it starts fine. Also runs fine. I havent got a diesel compression tester.
23rd Mar, 2006 at 12:24:09pm
Havent checked the filter i'll do that after lunch |
23rd Mar, 2006 at 12:30:19pm
Just stick this in google
23rd Mar, 2006 at 12:38:41pm
Cheers Dangerous that worked a treat. Got a pritty good idea what i need to do after lunch |
23rd Mar, 2006 at 12:42:47pm
On 23/03/2006 11:08:26 AlexF2003 said:
you should see 30-80 amps for about 20 seconds. 30 to 80amps? Maybe 40 A Max with all 4 plugs in series. Individually 6 to 10 amps per plug is more like it, as I can test the current draw using my multimeter fitted with a 15A fuse and it does not blow. If all the plugs are glowing and it isn't starting have you checked for an air leak somewhere? If the injector leak off pipes are split or a union leaking it will drag in air be difficult to start. Although I hate to say it but the small TU series diesel engines are well known for head gasket/piston ring/bore problems I am afraid.
23rd Mar, 2006 at 01:24:44pm
I guessed....
AlexF |
23rd Mar, 2006 at 02:21:01pm
lol, thanks for that info Tom.
Edited by Skinns46 on 23rd Mar, 2006. |
23rd Mar, 2006 at 02:24:46pm
the glow plugs take 8 amps a piece!
23rd Mar, 2006 at 02:50:24pm
When I googled it,A problem using non peagout fuel filters was mentioned ,as the non genuine ones let the fuel flow back to the tank
23rd Mar, 2006 at 02:52:46pm
Sounds worth some further investigation to me. good find Bri.
23rd Mar, 2006 at 02:54:47pm
Are the pipes your talking about the ones that go from one injector to the next then back to the tank? I've just wiggled one and can deffo hear air. If i'm gonna order some of this stuff...has it got a technical name?? Slippage?? |
23rd Mar, 2006 at 02:57:43pm
last post on here
Edited by Dangerous on 23rd Mar, 2006.
23rd Mar, 2006 at 02:59:44pm
On 23/03/2006 14:54:47 Skinns46 said:
Are the pipes your talking about the ones that go from one injector to the next then back to the tank? I've just wiggled one and can deffo hear air. If i'm gonna order some of this stuff...has it got a technical name?? Slippage?? Yes they go from injector to injector. It is known as leak off pipe. I think most motor factors will be able to supply you. Don't bother going to Peugeot, I tried to order some from them before, waste of time and effort and also they wanted to charge a fortune! Over time you will probably find they have gone hard, and so the barb on the pipe they push onto is not sealing any more.
23rd Mar, 2006 at 04:05:08pm
Well i've just fitted new 'leak off' pipes. (£3.50 a meter :) ). I can see why an after market filter would cause a problem. I'll try and order one.
23rd Mar, 2006 at 04:14:54pm
What great information in this post!
Edited by turbodave16v on 23rd Mar, 2006. On 17th Nov, 2014 Tom Fenton said:
23rd Mar, 2006 at 07:14:06pm
it will start fine!
24th Mar, 2006 at 09:37:10am
Who would have thought it. It started first time.
24th Mar, 2006 at 09:44:14am
well i knew ....lol
![]() 2102 Posts Member #: 432 Post Whore Swindon |
24th Mar, 2006 at 09:45:17am
Fair plays lads,
24th Mar, 2006 at 10:24:07am
go benross!
AlexF |
"Purolator"
