Home > Help Needed / General Tech Chat > fuel pressure
Carl
Member #: 95
liverpool-on-sea
any ideas on fuel pressure i think ive read somewhere that 4psi on idle and 10 psi on boost is this about right?
1310turbo
Member #: 41
i have put a fuel pressure gauge inbetween the regulator and the carb, mine reads between 3-5psi, i dont know what pressure it should be on boost tho as havnt had it on the rollers yet
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
Should be set 4-5 psi at idle. The fuel pressure will rise with the boost, so you only need to set it to this at idle.
Phil. *smiley*
minimark
Member #: 19
newcastle
above is right but you`ve got to check it stays 3 to 4psi above boost at high boost levels or you could end up with a flame thrower!!!
Edited by minimark on 14th Mar, 2004.
True !! lol
Phil. *smiley*
Carl
Member #: 95
liverpool-on-sea
thanks guys ill set it this week *smiley*
For a good and cheap fuel pressure gauge (amongst other things) go for a gunson lo-gauge. Does the job and more *smiley*
