| Home > Help Needed / General Tech Chat > mysfiring nightmare | |||||||
14th Mar, 2004 at 10:21:26am
I have passed the entyre past day from 8 in the morning to 4 in the night trying to solve a mysfire on my last builded turbo. |
14th Mar, 2004 at 04:06:25pm
I have had a miss fire in my mini for a year. it goes away as the revs build up.
244 Posts Member #: 34 Senior Member |
14th Mar, 2004 at 06:49:58pm
Have you replaced the plenum to carb gasket?
14th Mar, 2004 at 11:39:42pm
Fab- connect a small (lamp from the speedo is a good example) across the coil. This will rule out the ignition once and for all.
15th Mar, 2004 at 07:08:11am
I was certainly very tired at this moment, sometimes it is better to let the problem as it is, go back home drink a bear eat soething and have a good night, then solve the problem,
15th Mar, 2004 at 10:14:05am
Well, there you go - We've all been caught out with this pipe at some time or other!
15th Mar, 2004 at 11:22:02am
Like TurboDave mentioned it is THE main problem with turbo HIF?s. Get rid of it.
![]() 263 Posts Member #: 40 Really Very Very Advanced 'Member' Stratford upon Avon |
15th Mar, 2004 at 02:13:03pm
15th Mar, 2004 at 04:38:00pm
You can just replace it with a new piece of decent fuel hose, or block it off.
15th Mar, 2004 at 04:57:57pm
Cheers guys, i'll give it a go.
15th Mar, 2004 at 05:06:59pm
Which pipe is this...
AlexF |
15th Mar, 2004 at 05:48:27pm
its the pipe that comes out of the top of the carb and back into the side On 15th May, 2009 TurboDave said:
15th Mar, 2004 at 06:30:21pm
Edited by iain on 15th Mar, 2004. |
46 Posts Member #: 171 Member Portsmouth, Hampshire |
15th Mar, 2004 at 06:56:09pm
So is it just the case that if it leaks it will perform badly or could it become blocked?
1 Posts Member #: 209 Junior Member |
15th Mar, 2004 at 11:25:51pm
I have a standard metro turbo running the normal 5psi boost.
16th Mar, 2004 at 12:50:45am
check everything mentioned above... turbo 16v k-series 11.9@118.9 :)
16th Mar, 2004 at 10:40:20am
When you say that blocking off the pipes you just do like with the anti run on pipe? bolt in the end of a pipe with a jubilee clip on it?
17th Mar, 2004 at 07:29:21pm
yes bolt the end of the pipe and clamp it, or take sometning which go in the pipe and bock it, then put it at his palce; this pipe isn't used to pressuride , the float chamber, it is leaning the mixture at part throttle , ie stady slow (60/70) speed on the motorway,
