Home > Wanted > (still)Wanted Metro hyd clutch bits
Dangerous
Member #: 417
Pedal box,cover and master cylinder I think ???
cables not lasting very long *frown*
Edited by Dangerous on 5th Sep, 2006.
Carl
Member #: 95
liverpool-on-sea
pm sent
Dangerous
Member #: 417
On third cable now *frown*
Heres what I need anyone
Pedal Box
Bulkhead Mounting Plate (hyrdaulic one is different as it has a hole for the clutch master cylinder) You may also need to enlarger the hole for the brake master cylinder to accomodate the servo)
Clutch Slave Cylinder
Longer Hydraulic Clutch Arm
Clutch master cylinder.
These parts will need to be sourced from an 1980- 85 Metro, after which they conveted to cable.
Dangerous
Member #: 417
Still wanted (cables are c@@p)
might see if I can get a mini clutch pedal in the metro pedalbox then use a mini slave.
Or a slave that works by pulling instead of pushing
giallofly
Member #: 164
The Stig..
Newport Pagnell
give me a buzz tonight Brian...
i might have just the thing in the garage...
