| Home > Help Needed / General Tech Chat > Drilling Through Fiberglass | |||||||
27th Mar, 2006 at 11:36:05am
Some tips please, I always seem to damage the gelcoat.
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
27th Mar, 2006 at 11:44:29am
I'd tape over the hole, and drill slowly with a sharp drill.. |
208 Posts Member #: 438 Senior Member London |
27th Mar, 2006 at 12:02:52pm
Use a very sharp metal drill bit. If you can, grind the drill with a shallower angle at the tip.
27th Mar, 2006 at 12:08:44pm
Wood bits are definatly better for smaller holes, I reckon those flat wood bits should work for larger holes and holesaws for really big holes. go through from the gel coat side and use a light pressure and generally go easy, i reckon a slowish speed should help too, around 750 rpm?
