| Home > Help Needed / General Tech Chat > Oil filter housing to blank or not to! | |||||||
27th Mar, 2006 at 01:45:01pm
right the oil filer housing bypass valve,
27th Mar, 2006 at 02:16:25pm
blank it |
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
27th Mar, 2006 at 02:38:20pm
gotta blank it, very important on engines which munch their gearboxes/cams often. Minispares sell a grub screw to plug it up, but i cant find it now. I've seen the future and tbh its Pie
27th Mar, 2006 at 02:40:49pm
Definately blank it, i was amazed at how weak the spring was so must allow quite a bit of unfiltered oil past. The high oil pressures when the oil is cold must easily open it. -MINI CLUBMAN 1380 TURBO- |
27th Mar, 2006 at 03:28:11pm
Blank... On 17th Nov, 2014 Tom Fenton said:
27th Mar, 2006 at 03:31:18pm
What is this mod?
27th Mar, 2006 at 03:37:32pm
The valve you are thinking of wil is the oil pressure relief valve, loacted under the big hex cap just below where the oil pressure gauge take off is on the block.
27th Mar, 2006 at 04:15:01pm
the problem comes when you start the engine on a cold day and it bypasses due to the viscocity of the oil. Thia apparently happens on nearly every cold start regardless of the condition of the filter. I've seen the future and tbh its Pie
27th Mar, 2006 at 04:26:32pm
That is another issue - for very cold climates , you can in theory build up ridiculous pressures that could cause pump damage, burst the housing - or even worse - burst the internal of the filter sending all manner of crud towards the main bearings.
27th Mar, 2006 at 05:39:03pm
the thinking behind the leyland engineers was
1300 Posts Member #: 829 Post Whore essex |
28th Mar, 2006 at 10:05:32pm
leyland did a oil filter with a magnet in the filter to stop the metal in the oil going round the engine i think the part number of the filter was GFE21 1293 Turbo mini
60 Posts Member #: 629 Advanced Member Colchester |
29th Mar, 2006 at 09:27:06am
I've be looking into getting one of these, solves the problem with the oil filer housing bypass valve and look cool too |
29th Mar, 2006 at 08:55:48pm
good idea off iain, pete
30th Mar, 2006 at 07:18:34am
plenty of filter heads here
