| Home > General Chat > 'Sodium' Exhaust valves - what size? 29mm??? NOT! | |||||||
15th Mar, 2004 at 12:08:11pm
A typical case of going off what everyone else had always said. On 17th Nov, 2014 Tom Fenton said:
15th Mar, 2004 at 04:42:49pm
yet another good piece of information!
AlexF |
263 Posts Member #: 115 Senior Member Austria, near Vienna |
15th Mar, 2004 at 05:46:54pm
Hi Dave!
Bimmer Twinky headed and turboed A-Series:
15th Mar, 2004 at 05:50:20pm
good work for the valves Dave , I will have to check mines. 6581 cranks in place 6232, what is the difference?
15th Mar, 2004 at 05:51:01pm
15th Mar, 2004 at 05:57:54pm
15th Mar, 2004 at 06:10:16pm
No-one really knows about the differences in the cranks Fab - i suspect it is a different material (why make a new forging, or insert for the forging if all you're doing is changing heat-treatment) and judging by the appearance, and the fact they seem to last so long (mine is still std/std for example!!!), they probably have some 'extra' heat-treatment process...
15th Mar, 2004 at 06:25:43pm
Ive got a couple of heads in the garage, ill have a check. |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
15th Mar, 2004 at 07:30:05pm
mmmmmmm
15th Mar, 2004 at 07:32:07pm
148 Posts Member #: 98 Advanced Member Slovenia |
16th Mar, 2004 at 07:27:07am
I measured mine yesterday. They are in the head and I hope that measuring was right.
Edited by gregor on 16th Mar, 2004. |
16th Mar, 2004 at 08:20:27am
strange.....
16th Mar, 2004 at 10:06:29am
stock valves!
16th Mar, 2004 at 10:31:00am
do they have part numbers on them?
AlexF |
17th Mar, 2004 at 11:22:02am
Ok Guys I?ve just checked mine from a fairly new head and the Exhaust is 29.4mm (TAM1361) and the Inlet is 33.25mm (TAM1330 M) if that?s any help.
Edited by Doodmeister on 17th Mar, 2004. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
17th Mar, 2004 at 12:05:17pm
Forot to not the numbers, but i measured more goosed valves from the depths of my 'shed' and found them to be 29.3-29.6mm...
18th Mar, 2004 at 01:36:38pm
That reminds me on a Toyota D4D (is it?) engine I just saw. The valve seat was 2mm from the edge of the valve. The solution was to make the valve 4mm smaller which improved flow and grunt. It would also be possible to move the head valve seat of course.
, unlucky, my heads have the 29mm ones
