Page: |
Home > 998cc > Does LPG not work without high compression? | |||||||
![]() 3341 Posts Member #: 218 Post Whore Bingley, West Yorkshire |
31st Mar, 2006 at 07:55:49pm
Just been told that on my 998 turbo ill never get it to run on LPG because i wont have high compression, is that true?
31st Mar, 2006 at 08:00:33pm
I should have posted the question on help needed i think :(
31st Mar, 2006 at 08:05:32pm
I didnt realise there was more than one on that page, this is the one i have.
![]() 160 Posts Member #: 1085 Advanced Member Netherlands |
14th Jun, 2006 at 09:14:57am
1963 Cooper
![]() 6749 Posts Member #: 828 Post Whore uranus |
14th Jun, 2006 at 02:09:20pm
On 31/03/2006 19:55:49 feebleuk said:
Just been told that on my 998 turbo ill never get it to run on LPG because i wont have high compression, is that true? no its not . Also if anyone knows about LPG instalations, the mixer was in the air filter intake (metal tube before the carb). If i was putting it on a NA mini i would just drill a hole into the same part and use an airbox, but im not going to be able to do this, should i be placing it behind the carb just before the plenum? before the turbo ,run it rich to make sure you dont get a lewan backfire ,this with an intercooler could be a bit noisy ...i managed to blow my airbox lid off on my astra running the restrictor ring the wrong way round !!! Im thinking that i might need to get a custom plenum made up, or some kind of spacer in between the carb and the plenum so that the mixer can be installed. yep the boost would blow the lpg out not suck it in if your on the boost side with the mixer , one experiment iv done is to atmospheric reference the pressure diaphragm on the vapouriser body ,to stop the engine cutting out on coasting ,and when the fan comes on in traffic ,you could boost reference this and then put the ring in the boost side of the inlet , ,it would be a experiment cos you still may not get enough density compensation cos the mixer is velocity reactive not density reactive ,bit like a carb ,but without the ease of tricking the float bowl and jetting for increased fuel flow at boost to cater for the density increase.. .then again ,you could very well take your boost signal for the vapouriser from the turbo outlet before any restriction ,and this would give you a increase in vapour pressure over the pressure seen in the mixer area and so increase the flow the more rpm you had ,as the restriction of the ic and so on became effective . another thing you could try would be to have 2 adjusting taps to the the mixer ,in parallel,and have one on a solenoid valve that would click in at a set boost so give you more gas . personally i think id run it through the turbo and ic and see what happened ,again stressing to run it rich at first to avoid a backfire ..(or chernobyl as its known ).oh and make sure you have a stonking strong spark,oh and remember your ign timing will nedd to be v diff to petrol. regards robert . Edited by robert on 14th Jun, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
Site Admin ![]() 9404 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
14th Jun, 2006 at 02:10:46pm
are you still goint to give this a go feebs? Team www.sheepspeed.com Racing
Page: |
