| Home > Help Needed / General Tech Chat > return feed | |||||||
45 Posts Member #: 982 Member new zealand rotoura |
2nd Apr, 2006 at 11:44:08am
just been thinking does it matter what size the return pipe to tank is for the regurlater. eg . does it need two be bigger than the main feed? sorry cant spell. my mini has a cold |
2nd Apr, 2006 at 12:26:35pm
yes should be bigger unless you put a restricter in the feed pipe
Edited by Dangerous on 2nd Apr, 2006.
1300 Posts Member #: 829 Post Whore essex |
2nd Apr, 2006 at 10:57:08pm
what if you use 8mm (flow)
1293 Turbo mini
831 Posts Member #: 908 Post Whore gateshead |
9th May, 2006 at 01:22:25pm
sorry to dig this thread up again, i'm reconing i will have to head down the return feed, turbo carb and turbo pump route.
balls to the blower!!!
