Home > Help Needed / General Tech Chat > Does this timing chain look ok?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Hi, before this engine was taken out there was a loud rattling which we thought was the timing chain, but ive takne the cover off and it all looks perfect. The timing chain is as old as the engine, about 3000-4000 miles or whatever it is, and its a dual type one.
The tentioner was slightly to one side though that might have been the problem.
Otherwise, it might have been something rattley in the old gearbox that was on it
Jackman
Member #: 984
Westhoughton, Bolton
To me id say that chan is ok.
Manchester Minis
Leonard
Member #: 806
Cirencester, Gloucestershire
some of the teeth on the big sprocket look very worn, especially the ones in the 6 and 7 o clock position
jamesfawcett
Member #: 218
hi, thats just oil dropping off them its a new cog, all i wanted to see really is if someone said something like "that looks far too loose" and it looks like its visually ok, thanks jackman
Agree with Leaonard - could be the picture though...
Take it off and properly inspect it all by twisting and rotating the chain.
Also - the tensioner doesn't act centrally on the chain - it's designed for a simplex (single row) chain. As it's on a duplex - and doesn't sit centrally - you shouldn't 'tension' the tensioner. Instead, just fit it such that it takes up the slack in the chain, but not actually putting any kind of load or tension on the chain.
jamesfawcett
Member #: 218
Oh, back in 2 minuets ill go get a close up of the tensioner!!!
jamesfawcett
Member #: 218
back!!
i felt the tension of it and it it just resting on it, its not forcing it or anything and it feels right.
I think this one might be a different tensioner because its on both chains
jamesfawcett
Member #: 218
Just wondering right, is there any way at all, that the timing chain can ever turn backwards...?
thing is, it was out of place when i took the cover off, and i think that it might have been pulled the wrong way arround the chain and maybe one of the "legs" on the bottom wasnt in place properly, so it was on an angle.
Could that have happened could the chain have moved backwards to cause that?
Only thing I can immediately see is the oil flinger is on back-to-front - and looks like it's been contacting something?
Check the timing cover.
Also - check the countersunk screws in the bottom of the backplate are indeed countersunk, and that they haven't unwound...
Jackman
Member #: 984
Whats that dave? Oil Flinger? Can you show me?
Manchester Minis
jamesfawcett
Member #: 218
dave come and live at my house for a week!
This is a mini forum, not a gaylord forum!! *wink*
Too bloomin right...
I was hapy to help you before... But now I've found out you're a puddle jumper, you can forget it!
Ok - the round 'disc' that is between the chain and the woodruff key on the crank is called an oil flinger;it's purpose is to 'fling' oil away from itself - usually to lubricate other areas - eg the chain... And it looks to be on back to front? and looks shiny around the 'outer' face like it's been rubbing on something (the timing cover)?
Edited by turbodave16v on 4th Apr, 2006.
doh! see you later big boys
oops double post, anyway im off to http://turbogays.co.uk
Edited by Nic on 4th Apr, 2006.
jimmy
Member #: 829
essex
your cam lock tab is a bit worn ??
1293 Turbo mini
icklemini
Member #: 745
Northampton
As dave has said - looks like the flinger is the wrong way around..
Also the tensioner is broken! - Hence the rattle (seen it a few times) - Look at the grren 'plastic' acting against the chain.. towards the bottom...
TTFN,
Dave
jimmy
Member #: 829
essex
I see it now yes
1293 Turbo mini
tensioner pad looks broken to me, near the bottom????
WOW - How did I not see that!!!!
Edited by turbodave16v on 5th Apr, 2006.
The oil flinger usually has an F stamped in. This does not mean France, it means Front!
jamesfawcett
Member #: 218
HAHA! I see whats broken now! Erm... of course i knew all along really it was a test to you *surprised*
