| Home > Help Needed / General Tech Chat > dump valve fitting... | |||||||
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
18th Mar, 2004 at 12:38:19pm
Ok, i was cleaning up my engine a bit yesterday and i noticed that there was a bit of silicone tubuing below the plenum chamber connected to a pipe underneath it. (in the picture below it is the pipe just under the number 7 of the lower picture) Edited by wethepeople on 18th Mar, 2004. NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
244 Posts Member #: 34 Senior Member |
18th Mar, 2004 at 01:30:08pm
The outlet you discribe is too small. Usually people weld in a 25mm pipe for the DV.
18th Mar, 2004 at 01:45:52pm
how effective is the dump having it fitted to the intercooler piping ?
18th Mar, 2004 at 01:59:10pm
the dumpvalve needs to be as close to the carb butterfly valve as poss idealy, so on the plenum is best. Make sure you place it so it fits under the bonnet, unlike Avonbars first batch!.
18th Mar, 2004 at 04:14:51pm
Yeah your right, it should be as close to the butterfly as possible, on my car it is near the plenum, but not on it. Seems to work OK, but I'll probably get it welded, next time I rempve the plenum.
