| Home > General Chat > For those thinking of / doing the K1100 head... | |||||||
6th Apr, 2006 at 06:05:34am
So, what are you thinking of for fastening the head to the block?
Edited by turbodave16v on 6th Apr, 2006. On 17th Nov, 2014 Tom Fenton said:
6th Apr, 2006 at 08:44:42am
I don't know a fat lot about this conversion, but just thinking laterally Dave, you mention getting some 3/8UNC caps to use in three positions, I personally wouldn't like to have to torque a head down using a thread this coarse into cast iron, could a stud not be made to allow the use of a nut at the top, I know you mention that room is tight, but how about a k-nut? Obviously you'd need to do some investigation into the torque they will withstand, just an idea.
6th Apr, 2006 at 08:49:52am
The other option I have thought of, how close are the centres of the original A series holes to the BMW holes centres on these three you mention?
6th Apr, 2006 at 09:26:44am
I belive others which done this in the past use the long ARP head studs and cut them down a few mm.
6th Apr, 2006 at 11:32:47am
So how many others are doing this conversion. Myself
6th Apr, 2006 at 11:43:15am
Simon at more speed offers them as a complete engine and has one running in his demo car as far as I know. http://www.twin-turbo.co.uk
6th Apr, 2006 at 11:59:23am
I was down there getting in his way on monday, this was lurking in the corner of the workshop.
6th Apr, 2006 at 12:59:45pm
I'm REALLY liking the helicoil suggestion tom...
6th Apr, 2006 at 01:36:03pm
Dave, I found some info on some propietory available thread inserts something like what you describe, I am fairly sure I saw them in the Demon Tweeks motorsport catalogue, they were called e-z-locks or something like that?
6th Apr, 2006 at 08:06:55pm
I have not, as of yet, found any problem using the A series long studs and nuts with the original BMW washer under neath the nut, though im at the same point as Jimster needing the block skimming and the deck re drilling to suit. The cams turn freely without any signs of binding. If need be the studs can be shortened and the washer ommitted giving plenty of clearance. I'll see if i can find a pic i took last year when researching the project.
6th Apr, 2006 at 08:10:02pm
On 06/04/2006 11:59:23 joeybaby83 said:
I was down there getting in his way on monday, this was lurking in the corner of the workshop. [/url] [/url]
Think he said his demo car will be up ready for the rolling road shootout on the 22nd (or 23rd? ) of this month. Still using the modified Minispares drive belt set up I see
Also the head is no where near being ready to work, as well as the standard injectors fitted worth of just over 100bhp Edited by Sprocket on 6th Apr, 2006. On 26th Oct, 2004 TurboDave16v said:
6th Apr, 2006 at 08:19:57pm
6th Apr, 2006 at 08:24:58pm
Scratch that.
6th Apr, 2006 at 08:36:34pm
Hmmmm - I was just looking for a solution that allowed the cams, can wheels, front plate, everything to remain in situ when you want to lift the head...
6th Apr, 2006 at 09:01:10pm
You mean similar to this??
6th Apr, 2006 at 09:17:38pm
aye - that kinda thing...
6th Apr, 2006 at 09:20:37pm
ooh i see, doh.
6th Apr, 2006 at 09:26:15pm
Well I'm not going to do the math - but I'd have thought that you could make your cam pulleys into verniers by boring say a 3" diameter through the middle (concentric of course) and mounting this on a 'lip' on the (new) vernier centre. You could then have a series of holes drilled around the plate that allowed you to (after removing the belt) to swing between say 2degree increments... Just depends on the outer tooth count and how that compares to the five 'spokes' in your original gears????
6th Apr, 2006 at 09:30:33pm
Im convinced. Though will still need ne adapters making up as well as my redesigned seal plates for both engine and head.
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
8th Apr, 2006 at 01:52:25am
Sorry not been posting on here, been busy getting the f1s ready for their first test so been working since 9 to this time every night!!! I have done the same as Mini Sprocket using the orig long mini 3/8 unc head studs and the original head bolts. As mine isn't a turbo the clamping force isn't a huge factor. On the cam front i have bought a belt drive kit for the sealing plate and am making the pulleys from "pulley bar" to the utilise the original oil seals on the belt drive kit. Got time to get on with the engine after monday so should be able to help some more. |
[/url]
