Home > Help Needed / General Tech Chat > gearbox is dying!
adam1330
Member #: 238
essex
my gearbox has recently been getting more noisey, then yesterday i was having trouble with it not going into 2nd when changing down, its ok changing up through the gears..then today it was jumping out of 2nd and reverse gear doesnt seem right??
what is likely to be causing this? and am i likely to be causing damage to the engine by keeping on driving it?
cheers!
Mini_Andy
Member #: 432
wow, would love to know the answer to this as this happened to mini befor i removed the engine......
so i will be rebuildig soon
(ps this inst the sole reason i removed the engine, one of many lol)
Well 2nd and reverse both adopt the same synchro hub - and sliding sleeve - and that's about it.
If it's doing strange things, then chances are something has worn and/or broken away. This is now in the oil shared by your engine...
Pull it and sort it out.
turbo hogster
Member #: 178
stowmaket suffolk
sounds like shagged syncro and selctor fork to me. plus about every bearing you could think off.
give me a pm and could give it a look over i live in stowmarket suffolk
