Home > Help Needed / General Tech Chat > water temperature
TURBO ME
Member #: 772
new york
n/a metro turbo
what is normal running water temp?
only have temp. gauge with c n h it was just running 3/4 of the gauge between n & h is this too hot?
eh naturally aspirated metro turbo?
id say thats probably ok, although a touch lower, eg 2/3's, would be nicer
82c is the correct temp standard engine
most peeps run a 74c stat on tuned engines
i would get a better gauge.
jimmy
Member #: 829
essex
If you have put the turbo engine into a mini you need to fit the mini sender from the mini head
it`s different
1293 Turbo mini
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
I guess that depends on what temp gauge he is using is it stock or 3rd party?
I must admit i use a stock mini one with an astra GTE Digidash and its fine
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
