Home > Help Needed / General Tech Chat > slave cyclinder rod
turbo shane
Member #: 982
new zealand rotoura
hows it all... when changing the metro setup on the clutch to the mini setup how long do u make the adjustable slave cyclinder rod?
my mini has a cold
What adjustable rod?
Explain some more!
Venom
Member #: 755
Portugal
i thought u just need to repalce the smaler cable actuated arm to the long hidraulic acting one maintaining the same wok an wok internals
turbo shane
Member #: 982
new zealand rotoura
i am useing the metro clutch and i have bolted on the mini slavecylinder on and the mini arm on but when i push the the clutch down the rod on the arm is to short that goes into the slave an it wont engage the clutch .
my mini has a cold
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
When you refer to mini arm i assume you mean the arm that pivots on the flywheel housing?
Try bleeding it again i had a similar problem with clutch not engaging after a thorough bleed it was ok.
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
jimmy
Member #: 829
essex
If you are using the metro clutch you need to use the metro short arm and slave
1293 Turbo mini
Venom
Member #: 755
Portugal
sorry dumb portuguese here i still dindt get it*blush*
i have a verto cable clutch engine
and a non verto hidraulic setup in the car were the slave cyl is bolted on tranfer casing and have the long type arm.
what exacly do i need to actuate my verto cluch?
can replace short arm for the long one and place the slave cyl in the same spot??
or do i need the plate that bolts on the wok to place a A+ slave cyl and keep the rest?
thank guys
Venom ,
I 'ASSUME' you have a mini aleady working with the long-arm setup with the slave mounted horizontally?
If so - this is a Pre-verto.
I'm now ALSO assuming that you've puchased a metro engine which is sat somewhere in you garage - ie NOT in the mini.
This unit has the cable slave setup as you comment.
Well - If you want this to work in yout mini, you need to puchase a Short Verto arm, a Verto pushrod, a verto slave and hose and a verto slave bracket, along with some short 3/8 UNC bolts, and a long 1/4" UNF bolt and some tube to make up a spacer.
Easiest option in my opinion; find a complete cover on ebay (or put an ad in the wanted section)...
This guid might help:
http://www.manchester-minis.cwc.net/techni...bleshooter1.htm
Edited by turbodave16v on 10th Apr, 2006.
Venom
Member #: 755
Portugal
you were wriht about everything dave the guide helped alot tanks i now understand what i must do
i didnt realize that existed 3 types of arms
cable
hidraulic verto
hidraulic non verto
ps is this the clutch pusrod that i need?
http://www.minispares.com/Product.aspx?pid=33668
Edited by Venom on 11th Apr, 2006.
