Home > Help Needed / General Tech Chat > Air Cleaner Question
dboatman
Member #: 744
Seattle, Washington, USA
My 1961 Austin Mini is fitted with a Garrett Turbo, but alas me lads, no air cleaner!!?? Is there a suitable air cleaner that will fit in the limited space allowed? Do i have to remove the Radiator every time to get to it? What say you guru's? Much thanks. Dboatman
Moved to "Help Needed" section TF
Edited by Tom Fenton on 9th Apr, 2006.
Most people run a length of flexible ducting and then squeeze a remote cone filter in.
i also like the idea of running a silicone 90deg bend off the turbo, just incase the wire inside the hose pops out and entangles itself in the turbines
dboatman
Member #: 744
Makes sense. Kinda snorkle thing. The most room for the cone would be on opposite side of radiator,right front fender, do they run the hose all the to the other side? Thanks mate.
Most people either run it to the front of the car radiator side of the engine, or place it on the bulkhead near to the wiper motor (on RHD cars anyway)
There is no fixed way of doing it you will just have to see how you can best fit it in on your car.
