Hi...
I am going to look at blackouts Mini tonight, its a big possablity that I'll have it off him...
So my other project needs to go...
I can thankfully say this is VERY solid, orginal floor everything... There is slight rusting in the quater light window sill, and the doors have rusted... other than, there are LITTLE bubbles in usawell places...
Only draw back with it, it had a bump ont he front (NOT right off) and it has had the front removed, was going to convert into flip front, I do have ALL the parts needed for the conversion (Wings, Braces bars, Solid mounts) The front does need welding up....
Still has orginal interoir, which is in BRILL condiction, needs a speedo thou, the 3 clock type, you can get these off ebay for £10-ish...
Steel wheels with disks up front, she is reg as a E reg, 1987.
Very good starter project as the floor is sound, as is most of the other body work... I also have the V5 etc
It is how you see in the pic below....
I am hoping to get £250 for her, will need collecting on a trailer, as she has no engine...
