Home > General Chat > Linered bores way to go
Dangerous
Member #: 417
Just had the head of the metro for the 1st time,It still has honing marks in the bores and no ridge at all up the top*surprised*,the car has been 106K but only on normal 3-7 psi boost.I've been running it at fixed 8 for the last 500.
Block is believed to be the origanal 1989 so linered.
Wonder how long they take to wear out*oh well*
Dunno mate but my 16valver block of choice has liners, though, low milege. If its good bad, don't know but I can still use standard size pistons which no one wants these days*wink*
it should see you out bri
you dont get much wear on the A+ blocks
NONE linered
compared to the A blocks
why this is so, there may be many reasons meterial spec etc etc.....
any one know? or care to speculate!
Dangerous
Member #: 417
The linered block is a WFM numbered one,I have a non linered turbo block I stripped that had an approx .003" ridge at the top.
so take it the liners that rover fitted are well hard spec
NONE linered
I don't have the same experiance at all. The A blocks I've dismantled with known milage has got exactly the same wear as the A+ ones. I do not think that the material has changed much. Infact, Vizard states that the A+ block are made of inferior material than the A ones due to cost reduction.
Rods are inferior on A+ engines as well.
80ies were the cost reducing decade, and just bacause some bearing or journal became bigger on the A+ does not mean it's better, just cheaper.
Nick
Member #: 154
Midlands
fuck me, i think someone need to change vegards tagline to 'i pick holes in everything...and i hate the A+'
*tongue* *laughing*
Dangerous
Member #: 417
Not talking about A and A+,The block I have is A+ from the time they(alegedly) had casting problems and instead of chucking the blocks,rover decided to rebore them and fit liners
what can you rebore the linered blocks to?
same as std? or would a 1380+ be out of the question?
Dangerous
Member #: 417
+.040" I think although I have read that they don't like boring them as they are hard
andeh
Member #: 97
Near Daventry, midlands
most places will turn your linered block away as they are much harder to rebore, +40 is also a bit sketchy as it leaves a very thin liner.
I also have a linered turbo block here which is similarly unworn, cept the pistons have det marks and one of the liners is scored. Have to admit, its tempting to swap out my planned daily engine rebuild and use the linered block
As far as I know, you can take linered block to 1380, but you need to remove the liners first :)
No, I don't hate A+ stuff, the valves are excellent *wink*
My views on A+ stuff are based purely on experience. Might be a coincidence, might not...
PaulH
Member #: 2340
Dublin Ireland
Is this true Vegard,
I have 5 MPI A+ linered blocks here, nice to get some use out of them insted of kicking them around the place.
On 17th Feb, 2009 Rob H said:
I'll take one off your hands if they are just kicking about :)
PaulH
Member #: 2340
Dublin Ireland
Shiping would be crazy Colin other wise you would be welcome
Prawn
Member #: 5232
basingstoke
are all MPI blocks linered?
no, not all of them
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Not all no...
AlexF
1430 Mk1
Member #: 7145
Linered blocks not the way to go.
If you look at steel liners under the microscope, they are pretty smooth, whereas cast iron is little bally things. Cast Iron creates a better oil film than steel. This is better for standard rings.
Uprate your rings to super duper chrome jobbies and I expect it all lasts forever. I had this conversation with an old engineer/mini racer who said there was a catch. It may have caused it to run hotter or something. There was a catch and it was better to stay iron over steel.
Anyone back it up/dismiss it?
Are the liners steel? The ones I've fitted recently have been iron.
The only backside on liners is that if they don't have a proper collar on top, this might cause some headgasket issues on the A-series. Seen it a couple of times.
Downside? Vegard.
I have had no problems with the liners I fitted to the 16v. I did however have them fitted such that they sit on the original bores at the very bottom, that way, they wont move up, nor down. Infact you would be hard pushed to determine whether liners were fitted
We have an office in Dublin, so we might still be able to come to an arrangement*happy*
nutter driver
Member #: 47
Not very sunny swanage
if anyone has a linered block that is past its best and is putting new liners in, please let me know, im dying to try coating the inside of some liners.......
cant do normal blocks at the mo, as we dont have a rotoplasma, but i can do liners!!
I've got one A block with liners with a heavy ridge, out of a Riley, smoked like a pig.
tadge44
Member #: 2500
Buckinghamshire
I have an A+ block which is linered and needs boring to +40 to clean it up to be of any use. Minisport refused to bore it to 1360 because they said it was already beyond that if the liners were removed so I,m now confused by the earlier assertion that a linered block can go to 1380.I have never heard of steel liners, either.
remember that "big" liners can be got to sleeve 1380's back to std.
