Home > Help Needed / General Tech Chat > measuring cam wear
Dangerous
Member #: 417
How do you measure it,Do you measure the dia of the peak and take of the dia at 90 degrees(i.e. base circle size)
Then check against what the lift should be*oh well*
andeh
Member #: 97
Near Daventry, midlands
most people who do std rebuilds have a pile and choose the best, not that it helps you.
Sorry dude, noidea
turbo hogster
Member #: 178
stowmaket suffolk
slick it in a block and use a dti gauge but saying that a new cam will show different lobe lifts any way.
just look for flat spots on the lobe tip
Dangerous
Member #: 417
The cam I have is only shinny on the tips the rest is black
Would this be classed as newish
turbo hogster
Member #: 178
stowmaket suffolk
ah yes i would say so, as long as all the lobes look nice and tipped with out any flat spots then a visual check sounds ok.
excessive cam ware sticks out like a spare prick at wedding.
Dangerous
Member #: 417
Yeah I did a cavalier one ages ago,where the followers arn't as wide as the lobes.
You could see where the cam used to be on the outer edges of the lobes
