Home > Help Needed / General Tech Chat > Metal Fuel line
jamesfawcett
Member #: 218
Bingley, West Yorkshire
im going to try and use metal fuel line this time instead of rubber piping through the car, does anyone have any photos of theirs?
I was really impressed by turbodaves stainless fuel lines.
Im using a MPI tank, and ive never used copper piping before. Is 5/16 close enough to 8mm?
I think i will run two rubber 8mm pipes down from the top of the tank and under the boot floor (with a fuel filter in the boot) and then im going to try and run the copper pipe along the floorpans where the original 6mm line is, is this what everyone does?
Ive seen these clips are they what you use?
http://cgi.ebay.co.uk/P-CLIPS-BRAKE-PIPE-C...bayphotohosting
Also is this fuel line any good?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...Y_BIN_Stores_IT
Will 25ft be too short?
Im going to run it up behind the front subframe and then join it to rubber 8mm hose again. Ill put the input into the regulator, and ill use a 8mm - 10mm adapter for the return on the regulator if thats right
Any help really really appreciated i cant find many photos of peoples fuel lines.
I did post up a part number of some Steel fuel line from Ford a few weeks back - AF was supposed to be checking it out?
Maybe if you have a ford dealer nearby, you can take the part number in and get a price quote yourself?
I suspect if that is indeed 'brake pipe' tubing, then the ID will be pretty small - and hence unsuitable. If you use steel - at least you know the ID is going to be plenty large.
The rubber-backed steel P-clips are the ONLY way to secure fuel line IMO.
25ft is plenty to do the job.
oh - and that is a really good price on the rubber lined P-clips. Buy two packs. Cheapest I can find them for over here is $7 for 10 + postage.
Edited by turbodave16v on 13th Apr, 2006.
if you install all the above you mentioned feebs
& make a neat job!
you will have the same setup as me make sure the fuel pipe is 8mm (id)
jamesfawcett
Member #: 218
Great!! thanks, just ordered two bags, £2 postage for both not bad.
Im looking for that thread now in your history dave thanks i missed that one.
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
If you goto a B&Q superstore/warehouse whatever they call them nowadays you can buy 8mm and 10mm microbore copper pipe in large lenghts for about a tenner!
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
Andys101
Member #: 611
canterbury
seems a bit steep for only 20 ??
i pay about that for a pack of 50
i'll find some prices and get back to everyone i might beable to help some of you out
