Home > Help Needed / General Tech Chat > Questions from slobbo !!
Dangerous
Member #: 417
Hi, You answered a few questions for me before and I hope heres a few more. I just got a turbo boost gauge and when I rev up the engine it goes minus up to about 8 minus. When I am driving along it goes to the plus side. Next, in the photos I am sending you there is a hose that is wide open. One end goes to the carb. What is this and where should the ends go? Thanks for the help. This is new to me and I can't find an explanation of how the turbo should look and what should be hooked up to what. I really don't know what I'm looking at. All the best, Slobo
Dangerous
Member #: 417
If you click the pics they get bigger
Supprised it runs like that
I think on the top pic the pipe should be going to the fuel regulater
On the bottom pic that is where the anti run on valve goes which is not really imprtent as long as its blocked off like it is
My boost gauge says about -15psi on idle
Edited by Dangerous on 14th Apr, 2006.
WTF?
How do peeps still get it wrong?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=106
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=3359
To name but two of many...
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
You're going to have a vacumm on idle as the turbo isn't producing any positive pressure or boost.
I'd say the blocked off pipe is the throttle lean off have a look
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
