Home > Help Needed / General Tech Chat > Is this a pre A+ distributor?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
is that an old style distributor?
I need to find an old pre a+ one and then get it welded up to get a fixed advance, is there anything i should worry about? Any old one will do really wont it after a clean up?
Dangerous
Member #: 417
Yes cus it has the clamp with 2 bolt holes attached,A+ has a separate clamp fixes to the block with one bolt
jamesfawcett
Member #: 218
great stuff ill bid on that then, ive not seen a pre A+ one before!
remember this has a points set up feebs
if thats what you want
icklemini
Member #: 745
Northampton
feeb - have replied to your wanted ad on 'finity about the dizzy...
TTFN,
Dave
