| Home > Help Needed / General Tech Chat > heeelp! - drive flange and hub nut - washer? | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
16th Apr, 2006 at 01:24:46pm
need a quick answer if possible, i have just put my flange and disk on and come to do up the hub nut but it looks to me like there should be a washer or something between the nut and the flange, but i have nothing hear and it was over a year ago i took it off so i cant remeber if there was one, is it suposed to be there? i know it porbably says it haynes but i left it at my old work and i am scared of my old boss!!!
16th Apr, 2006 at 01:29:34pm
Hahaha dan ill go get the haynes for you i should have rememeberd when i went to get the LCB. Ill go there tomorow morning Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
16th Apr, 2006 at 01:30:28pm
hehe cheers jimmy. also that lcb aint fitting! it all goes on untill you come ot put the Y-peice on and it just wont! lol
16th Apr, 2006 at 03:39:01pm
There is a split collar that goes under the hub nut, one side is tapered to centralise in the drive flange, the other side is flat for the hub nut to tighten against.
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
16th Apr, 2006 at 03:41:24pm
On your lcb have you already done manifold nuts up then try and fit the y piece? Whats going to break next!?
16th Apr, 2006 at 03:49:44pm
thank you top i will see if i can see anything from my boxes of bits when i took it al to bits, i can see the taper on the outside of the flange now,. thanks.
16th Apr, 2006 at 04:07:24pm
I had similar problem if manifold nuts were tightened y piece wouldnt fit so in end had to leave manifold completely loose fit y piece then tighten up manifold. Bit of a mess about but worked none the less Whats going to break next!?
16th Apr, 2006 at 04:35:58pm
16th Apr, 2006 at 05:08:40pm
Problem i had wit hthe lcb was i couldnt get it down the back of the engine! i cant remember why though or waht it was catching on, the other one i got went straight in place lol
16th Apr, 2006 at 08:55:12pm
wolfie are you far from me? postage will take longer than it will to go to local mini breaker but if its posible to pop round tomorrow then thats better...just read your in swindon, thats a way from leeds i think? lol thanks anyways.
16th Apr, 2006 at 09:50:49pm
who needs a y piece anyway Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
17th Apr, 2006 at 01:13:01pm
lol fumes dont taste nice and make me see funny things |
carl austin style!
