| Home > Help Needed / General Tech Chat > flywheel | |||||||
5 Posts Member #: 1010 Junior Member Cirencester |
16th Apr, 2006 at 07:05:02pm
Hi I am having trouble starting my new engine that I have just fitted. When i turn the key the starter motor just locks solid.
16th Apr, 2006 at 07:38:18pm
The pre verto ring gear has a chamfer on the outer(inner wing) side,as it engages from this side Edited by Dangerous on 16th Apr, 2006.
1300 Posts Member #: 829 Post Whore essex |
16th Apr, 2006 at 08:51:04pm
Look at the ring gear and if you can see a leading edge on it it is a pre engages flywheel (starter with solenoid on it)(metro/late mini) Edited by jimmy on 16th Apr, 2006. 1293 Turbo mini
16th Apr, 2006 at 09:24:30pm
Not locked the fly wheel with a long bolt on the engine mount have you??
16th Apr, 2006 at 10:44:51pm
yes it turns freely by hand and its a ultra light billet type flywheel. No chamfer on ring gear at all |
16th Apr, 2006 at 10:58:31pm
sounds like you want a verto starter then,I got a load of metro ones you can have for free Edited by Dangerous on 16th Apr, 2006.
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
17th Apr, 2006 at 12:37:09am
On 16/04/2006 21:24:30 Mini Sprocket said:
Not locked the fly wheel with a long bolt on the engine mount have you?? Does the engine turn by hand?? That old chestnut Whats going to break next!?
17th Apr, 2006 at 10:54:23am
The problem is that there are two different types of starters, inertia and pre-engaged.
17th Apr, 2006 at 10:59:20am
pre engaged ring gear
17th Apr, 2006 at 08:40:23pm
Good information there Axel on the ring gear teeth counts.
