| Home > Technical Chat > piston to deck height | |||||||
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
17th Apr, 2006 at 10:02:45am
what is the main thought on this, in the yellow bible it says to have the pistons flush with the block to try and keep detonation at bay and give extra power but thats on n/a engines does not say about turbo units any difference or should i get the block machined to get the block flush with the top of the pistons "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
17th Apr, 2006 at 10:27:49am
Yes the same applies on charged engines. But many poeple don't do this as it's an effective way of reducing the static CR. What they don't know is that combustion is not as effective which increases the possibility to ping.. That measn that the lower static CR might not be of any good.
21st Apr, 2006 at 09:10:57am
im no expert, but i would say keep the piston down the bore and reduce the compression ratio. if your yellow bible is Vizards book throw it in the bin, he is often wrong. the early MK1 Golf GTI 1.6 had a flat cylinder head so the chamber was all in the piston and piston to deck height. if your bible is right the engine would not work. a friend has one and it goes better than my 1.8 GTI
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
21st Apr, 2006 at 09:37:24am
I'd have the pistons flush with the block,
21st Apr, 2006 at 10:11:56am
It is and it isnt....
AlexF |
21st Apr, 2006 at 10:29:43am
On 21/04/2006 09:10:57 Turbo Shed said:
im no expert, but i would say keep the piston down the bore and reduce the compression ratio. if your yellow bible is Vizards book throw it in the bin, he is often wrong. the early MK1 Golf GTI 1.6 had a flat cylinder head so the chamber was all in the piston and piston to deck height. if your bible is right the engine would not work. a friend has one and it goes better than my 1.8 GTI i know its not an a series but if the principle is right then it would be right for all engines Russell So, tell me one engine that VAG has produced that has good efficient breathing and combustion?? The fact that the 1,6 goes better than your 1,8 has got NOTHING to do with the design of the combustion chamber. Camshafts, wear etc?? On 21/04/2006 10:11:56 AlexF2003 said:
It is and it isnt.... I have evidence of a 200bhp A-Turbo running with the pistons way down the bore!!! It shuldn't be right, but it works! Alex So?? Does this mean that it cannot be bettered? BS! On 13th Jul, 2012 Ben H said:
21st Apr, 2006 at 11:37:43am
Have a look at the Porsche/VW 2,5 litre that was found in the 944 etc. A HORRIBLE design by all means. They've got flat heads. Also have a look at the VR6 engines. HORRIBLE designs Flat heads AND flat pistons. NO Squish. On 13th Jul, 2012 Ben H said:
21st Apr, 2006 at 11:54:19am
It is and it isnt.... I have evidence of a 200bhp A-Turbo running with the pistons way down the bore!!! It shuldn't be right, but it works! Alex So?? Does this mean that it cannot be bettered? BS! So??? So its somthing to think about... and that is all... You really love shooting stuff down rather than talking about it don't you!! Alex AlexF |
21st Apr, 2006 at 12:03:32pm
No I don't. The fact that you know a 200hp engine with pistons down the bore does not mean that power end reliability isn't better with 0 deck height and bigger pistons/combustion chambers. On 13th Jul, 2012 Ben H said:
21st Apr, 2006 at 12:20:04pm
Alex.
Edited by turbodave16v on 21st Apr, 2006. On 17th Nov, 2014 Tom Fenton said:
21st Apr, 2006 at 12:22:17pm
OK point taken I should have said bananas...
AlexF |
21st Apr, 2006 at 01:01:17pm
surely running them down the bore cant be that bad? my mates running flat top omega's down the bore and his engines making 140 banana's @ 10psi, thats nearly an extra 50hp over stock from just an extra 3psi. His CR is 8:1 on a standard turbo head, but combined with a T2 and megajolt. On 20th Oct, 2015 Tom Fenton said:
21st Apr, 2006 at 04:25:15pm
wow i love all this slagging off, it makes my day at work so much more enjoyable!!!!
21st Apr, 2006 at 04:47:53pm
Shed, you put yourself right in the firing line if you come out with bollocks like that.
21st Apr, 2006 at 05:32:26pm
so the jist of the thread is that the piston should go to the top of the bore for somthing called squish.
21st Apr, 2006 at 05:42:55pm
OT but Turbo Shed could you change your avatar? I get all kinds of errors on both my computers viewing threads that you have written. I cant see anything else than a red cross there anyway. |
21st Apr, 2006 at 05:49:22pm
On 21/04/2006 17:42:55 miniminor63 said:
OT but Turbo Shed could you change your avatar? I get all kinds of errors on both my computers viewing threads that you have written. I cant see anything else than a red cross there anyway. Likewise |
21st Apr, 2006 at 05:59:42pm
OT but Turbo Shed could you change your avatar? I get all kinds of errors on both my computers viewing threads that you have written. I cant see anything else than a red cross there anyway. Likewise Done.
21st Apr, 2006 at 07:02:36pm
someone on here has there pistons proud of the block Crystal Sound Audio said:
21st Apr, 2006 at 07:13:18pm
thanks for changing that. it used to work but then i have not got web space of my own to host pictures on.
21st Apr, 2006 at 07:59:42pm
As I understand it, it is nothing to do with "efficiency", it has more to do with flame propogation, and most importantly, avoiding detonation.
21st Apr, 2006 at 08:11:24pm
but by having the flame in the correct place, the fuel gets burnt more efficiently and hence increased power and economy |
21st Apr, 2006 at 09:28:14pm
I would definitely have the pistons flush at the deck, not down in the bore. Pro engine builders seems to aim at 0,035-0,040" squish band in the best engines built in USA. Also, they have realised the benefits of smaller chamber, better spark plug location, squish and also dished pistons (dish mirroring the shape of the chamber). The squish helps to make the mixture more turbulent by "squeezing" the mixture away from outer areas of the chamber. This is often the location of pre-ignition or dieseling or whatever one chooses to call it. (Hot spots are another source of pre-ignition) Another benefit of the squish band is said to be the cooling effect of the band but I personally doubt if it has a major influence. By optimising the squish one does not have to compromise with ignition advance. So, with pistons flush with the deck and nromal mini head gasket we are in fact close to the quoted figure above.
21st Apr, 2006 at 10:35:22pm
so who's going to outline the differences between detonation and pre-ignition... or for that matter anti-ignition.
AlexF |
