| Home > Help Needed / General Tech Chat > stupid question? towbar | |||||||
17th Apr, 2006 at 11:31:45am
anyone ever fitted atowbar to a mini? just wondered where it bolts to. im thinking of fitting one to my clubby but id have to just fit it when i needed it then remove when i didnt. reason is in my roofrack post.
17th Apr, 2006 at 12:00:11pm
they bolt to the subframe
![]() 1014 Posts Member #: 238 Post Whore essex |
17th Apr, 2006 at 12:03:25pm
my mini originally had a towbar fitted when i first brought it, from what i remember it was mounted on the subframe and through the floor in the rear seat base. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
17th Apr, 2006 at 12:19:22pm
adam has the right idea, they have 2 long beams to the rear heelboard, (think its to stop it flexing more than anything else). "Turbo's make torque, and torque makes fun"
567 Posts Member #: 102 Post Whore Pennsylvania USA |
17th Apr, 2006 at 09:32:40pm
Mine was to the subframe and through the boot floor. |
17th Apr, 2006 at 09:38:48pm
I made my own,2- 3 foot(approx) lengths of angle bolted/welded back to back to make T shape,plate welded on the end to take ball.Bolted to subframe at back with slot cut in at front so it hooked the front of rear subframe between the handbrake cables with a bolt there too.
