| Home > Help Needed / General Tech Chat > My turbo didnt make it home :( | |||||||
22nd Mar, 2004 at 10:19:37am
Hi, went to kent from west yorkshire yesterday to pick up my mg metro turbo. its all in really good condition, loads of new parts including dif, gearbox, clutch and loads of other mechanical bits. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
244 Posts Member #: 34 Senior Member |
22nd Mar, 2004 at 10:58:55am
Broken oil feed pipe perhaps??
22nd Mar, 2004 at 11:44:51am
yeah first thing i thought of was a broken oil feed pipe!
22nd Mar, 2004 at 12:11:46pm
RIGHT sorted it. Fanbelt had snapped, the oil was just burning off the engine. I feel really stupid now, only just saw the car for first time in the ligth after asking here, i was just asking to see where i should check. It had caused it to overheat. When i just checked it, its used no oil, ive filled up the water again and it started on first turn over. Im really sorry for wasting your time, i just wanted to check possibilities before i tried starting it again.
22nd Mar, 2004 at 12:24:28pm
DOn't be sorry!!!
AlexF |
22nd Mar, 2004 at 01:06:29pm
So was it the battery light then not the oil or water lights?
22nd Mar, 2004 at 09:01:01pm
no, the oil light came on too, thats what worried me! I am thinking though, it could be because i turned the ignition off!!
![]() 82 Posts Member #: 78 Advanced Member milton keynes |
22nd Mar, 2004 at 09:43:26pm
Couldnt say about the grinding noise but i no someone who had problems with the anti run on valve it made the car pop and bang as soon as you got over 3500 rpm this is where the boost is increased as soon as that was changed the car ran sweet again. dont no if that could be part of the problem, i have blocked mine off. |
23rd Mar, 2004 at 10:10:34am
put a set of mole-grips on the pipe and go for a spin...
24th Mar, 2004 at 09:38:27am
ok, im going to close the pipe thats inline with the antirun on valve and unplug it and take it out. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
24th Mar, 2004 at 06:46:54pm
ok, followed all that through thanks, everythings perfect, its all mint and clean. As for the anti-run on valve ive been everywhere today trying to get one, only ones i could get are the larger ones with no run off pipe. Got one anyway im going to give that a try.
26th Mar, 2004 at 08:11:59am
Anti-run on valve only bleeds are iirc :) |
26th Mar, 2004 at 06:58:40pm
No luck, still does it. I replaced the air filter pipe, and checked that the arm to the wastegate down the right hand side (think thats what it is?) moves, and it does really freely. Sounds like an exhaust gasket has started to blow, so i am going to take the manifolds off this sunday and work out what goes where!
