Home > Help Needed / General Tech Chat > Are these the right K nuts? + pics of manifold
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Nic's guide on fitting a mirage manifold is excellent, just wanted to check though, it says get some K nuts, and so i bought some online. Do these look about right?
Also, heres a pic of the stainless lambda sensor boss welded onto my manifold...
jamesfawcett
Member #: 218
Ooops pics wrong way round :(
yep, what thread did you get?
Mirage
Member #: 119
You need 5/16 UNF for your head studs and 8mm ones for the studs on the manifolds.
I send out 2 of each with the manifolds, which is enought for the fiddely areas.
jamesfawcett
Member #: 218
Ah yeah i got them thanks, just in the guide it says to get 5 of them :)
its alright all will be fine
Just been deciding on what nuts to use one mine! ha ha! already had it sorted and now i read this! lol! still tempted with some modified cap head bolts though, like the thought of being able to remove the manifolds easier.
ian_mini
Member #: 485
I'm about to do the Mirage Conversion this coming week,
and still can't seem to find these K-nuts,
have looked on every link on google, screw-fix direct etc etc
and still no luck,
Can someone tell me where to order them from?
Thanks,
Ian
antman
Member #: 358
Snetterton, Norfolk
Trident at silverstone is probably the best place to try i think they have a website but not sure, a quick google should show u
ian_mini
Member #: 485
cheers antman, found them straight away!
jamesfawcett
Member #: 218
Mine are actually from a Go-Karting place. They are actually wheel nuts for a go kart *wink*
