| Home > Help Needed / General Tech Chat > Inner primary gear bush | |||||||
23rd Apr, 2006 at 09:14:03pm
Just had a look at a set of second hand drops I got-They were cheapish as the bloke said ''Split my engine yesterday to find that the primary gear front bush is worn, which means it'll need replacing"
23rd Apr, 2006 at 11:17:35pm
24th Apr, 2006 at 12:33:26pm
Thanks
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
24th Apr, 2006 at 04:49:11pm
i used a floating one with no probs, though i have to say i havent had it appart to check. I've seen the future and tbh its Pie
24th May, 2006 at 12:34:47pm
Next question
24th May, 2006 at 01:30:41pm
23rd Apr, 2009 at 11:36:56am
I need to have the rear bush changed and "reamed" ? Do you guys know of anyone in the UK who can do this?
23rd Apr, 2009 at 12:49:53pm
On 23rd Apr, 2009 Vegard said: I purchased a set of drops to find the bushes had not been finished so I pulled the bushes out of the original primary gear and fitted those to my new straight cut primary gear and the bore dimension was bang on the money.
I need to have the rear bush changed and "reamed" ? Do you guys know of anyone in the UK who can do this? I guess that's cheaper than doing it over here. They come out real easy. Own the day
23rd Apr, 2009 at 07:35:44pm
The problem here is that we have several primaries with worn bushes and need them replaced. We are searching a place who could do that for us. |
23rd Apr, 2009 at 08:19:34pm
I need to have the rear bush changed and "reamed" ? Do you guys know of anyone in the UK who can do this? I guess that's cheaper than doing it over here. KAD did mine On 5th Sep, 2011 Vegard said:
24th Apr, 2009 at 10:46:38am
On 23rd Apr, 2009 miniminor63 said: Only takes a few minutes per to trty and swap them out.
The problem here is that we have several primaries with worn bushes and need them replaced. We are searching a place who could do that for us. Own the day
