Home > Help Needed / General Tech Chat > Bulkead box or not to??
Right, while i an doing a major overhaul of the body (here ) I have been considering fitting a bulkead box just in the event that i may fit a carb turbo at some point in the distand future. The thing that has realy been putting me off is the amount of butchering required and the main reason ( some may think silly) the heater assembly sticks further out.*frown*
So, I need some help people,*blush* on deciding whether to or not. Pictures of how much the heater sticks out when refitted (and i dont want to know that its easier to leave it out, I want heat in the winter).*wink*
TBH i was not going to do this till recently as i had always thought about either making my own manifolds Mirrage styl'ee for the IHI turbo's i have or the Mirrage manifolds them selves:cool:
Please help, i'm confused and undecided.*oh well*
jimmy
Member #: 829
essex
I`ve fitted my turbo box in so i well take a picture for you tommow so you can see the heater when the bulkhead box is fitted
1293 Turbo mini
chears mate, thats smashing *wink*
Spank
Member #: 909
Did not check the link, but I think you can get away without putting in a box even using a standard metro turbo exhaust manifold. I put in a box, but I also drilled the motor mounting holes in the subframe about 1" further forward. Of course, I had to move the shift linkage an equal distance forward, and I had to lengthen the dogbone engine steady, but looking back at the firewall, I don't think I needed to put the box in!
I did this to a clubman front end, though, so it might prove a little too tight in a round nose. Also, you may need to fit a remote oil filter head as the front subframe cross member prohibits the filter from dropping down far enough.
I think drilling the mounts further forward (check for driveshaft clearance), moving the shift linkage forward, and finally tilting the top of the motor forward a few degrees would surely work without the need to put in a box.
--Spank
I wouldn't bother, it's a lot of work for nothing if you're not fitting a turbo.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I would not bother either. Once you have the K1100 working, do you think you will ever go back to a 5 porter?
http://www.twin-turbo.co.uk
Carl
Member #: 95
liverpool-on-sea
in your situation i dont think i would bother either*smiley*
SumpNut
Member #: 28
Moving the engine forward an inch really will not give the clearance required when using a standard metro turbo setup.
With a bulkhead box properly fitted there is no reason to move the engine mounts at all. It is very tight at the front in a round nose mini anyway.
Whats the loadings like on the CV joints when a movement forward like this involved?
The only way round it is to use a mirage or custom setup.
IMO I really wouldnt bother - the heater will never fit right afterwards (been there done that) And now I'm a big fan of the mirage setup on my new shell.
And i especially wounldt bother with your 16v plans that may end up in this shell
Just so people know the 92 on sub frames already have the engine moved aboit 1/2 inch further forward from the factory and space is alreadt limited at the front
I am think of leaving it, thanks for the help. Still, would like to see a picture of the heater fitted with a box fitted.
Thanks
MS
t3gav
Member #: 229
Gavin@minispares.com
kent
I didnt really have a problem with the heater, just moved one bracket a little and with a few zip ties the heater looks nearly factory fitted, hope this helps.
SumpNut
Member #: 28
Mini sproket check your e-mail im going to try and send you a picture.
I cant compress it as you need the full thing to zoom into to see my heater.
jimmy
Member #: 829
essex
Sorry its late but I hope this helps
Edited by jimmy on 27th Apr, 2006.
1293 Turbo mini
I was the same Pete, couldn't bring myself to cut my shell either. I fannied about for about 4 hours measuring and marking and measuring again.
I got my Dad to do it instead in the end!
ehz
No picture
I dont think I'll carry out the butchery*surprised* too much hassle for little gain in my case anyway*tongue*
Thanks again people*happy*
