| Home > Help Needed / General Tech Chat > Floating Gudgeon Pins | |||||||
24th Apr, 2006 at 10:43:03am
What are peoples opinions on floating pins? I am thinking about having my rods machined to have floating pins and then use teflon caps?
24th Apr, 2006 at 11:40:12am
I think you should go for it! :)
24th Apr, 2006 at 02:13:45pm
ive got fully floating pins with circlips. handy if you melt a piston, but the clips are a little tricky to remove. my only point is my engine was done by a well known engine builder and the small end has been machined out but there's no bush or bearing in it that i could see. there is also no wear on the pin so all seems well. |
24th Apr, 2006 at 02:39:36pm
With circlips I would definately use teflon/nylon buttons as well. I have previously had one get out and wreck an engine.
24th Apr, 2006 at 02:44:38pm
Tom
24th Apr, 2006 at 03:23:54pm
I've just binned the circlips and fitted teflon buttons.
24th Apr, 2006 at 03:43:59pm
ive got forged omega's if this helps
24th Apr, 2006 at 06:52:34pm
ive gone to floating gudgeon pins this year, aparently you can rev higher with them and its a bit of insurance against anything popping out! |
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
24th Apr, 2006 at 07:16:21pm
i have floating pins in my omegas, my rods were machined by arrow for the small pins they use. Worth noting that the rods supplied by minispares, ones im using, as being S-reproductions rods are well on the piss. Infact the guy at arrow said that they were 20 or times out of spec (over their top amount of missalignment allowed, i think it was 20 anyway). This means that the little end wanst parallel/aligned to the big end. This can cause some really severe wear.
24th Apr, 2006 at 08:44:20pm
On 24/04/2006 14:44:38 Turbo Shed said:
Tom i assume you mean fit teflon bushs as well as circlips. i've not had a problem but will trust you on this as its better to be safe than sorry! yes, sorry, wasn't very clear on that. If I ever built another engine with circlipped gudgeon pins I would definately be fitting the teflon buttons to make sure the clips could not get out. I learned this lesson the hard way :(
26th Apr, 2006 at 12:41:05pm
Have you guys instered a bush into the small end, or not bothered? On 15th May, 2009 TurboDave said:
26th Apr, 2006 at 12:56:06pm
On my S rods from my 1418cc engine there are no bushes.
26th Apr, 2006 at 01:05:03pm
that was my thinking,
28th Apr, 2006 at 06:29:20pm
no turning back now! just picked up my rods from the machine shop. I now have floating pins On 15th May, 2009 TurboDave said:
