Home > Help Needed / General Tech Chat > Can some one identify this crank number
SurfToLiveLiveToSurf
Member #: 748
Cirencester, Gloucestershire
EN 16T? or 12A 670? Both written on it.*smiley*
thanks mark.
1310 - Supercharged 16v Twin Cam - 190BHP - SC Built.
1293 - Turbo 16v Twin Cam - Build Commenced
Dangerous
Member #: 417
En 16 is the metal type (en40 is steel crank)
Dangerous
Member #: 417
http://www.minimania.com/web/CatPage/2-7/C...operCatalog.cfm
8G2734 Crankshaft 1.5" diameter tail size (12A670 casting) 1 850cc
Edited by Dangerous on 24th Apr, 2006.
Member #: 748
cheers dangerous.
does anyone have a list of casting numbers are for which cranks?? I have a few cranks which I don't know what they are.
andeh
Member #: 97
Near Daventry, midlands
http://www.minispares.com/Article.aspx?aid=164
HTH
Member #: 748
I'm not sure, just found it in my garage will have another look and get back to u mini1071s.
Not sure of its condition tho!
mark
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
For the lazy...
22A62 850cc - Early type with oil feed for primary gear, 1.375" dia. tail
22A63 850cc - Early type with oil feed for primary gear, 1.375" dia. tail
22A298850cc - Early type thin-nose crank, 1.375" dia. tail
12A670 850cc - Later type with 1.5" dia. tail
12A298 997cc - Original Cooper crank
12A375 997cc - Cooper crank with oil feed hole for primary gear
12A595 998cc - Early EN16T spec
12A1451 998cc - Later, pre-A+ EN16T spec
BHM1436 998cc - A+ spec, 1985 onwards (12A1451 forging)
12G82 1100cc - Standard across the board transverse A-series EN16T spec
AEG330 970cc - EN40B forged, non-cross drilled
AEG171 1071cc - EN40B forged, non-cross drilled
AEG315 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, non-cross drilled
AEG316 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, non-cross drilled
AEG479 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, cross drilled
AEG480 1275cc - Cooper S, EN40B forging, Nitrided, 1.625" dia. big ends, cross drilled
AEG623 1275cc - Cooper S, EN16T forging, Tuftrided, 1.625" dia. big ends
12G1287 1275cc - Non-S, EN16T with 1.625" dia. big ends
12G1288 1275cc - Non-S, EN16T with 1.625" dia. big ends
12G1505 1275cc - Non-S, EN16T with 1.75" dia. big ends
12G1683 1275cc - 12G1505 forging, non-S, EN16T with 1.75" dia. big ends, Tuftrided
CAM6232* 1275cc - Rolled-fillet radius on bearing journals, A+ with 1.75" dia. big ends
The turbo is CAM 6581
at least thats the one I have taken from a few turbo engines :)
Alex
AlexF
thanks for that alex
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
On 25/04/2006 18:28:34 mini1071s said:
That's really helpful Alex! Thanks. Should move to the FAQ section when the thread is done?
To add one more.
12G2827 south african 1071 big journal crank.
Tom has done it already!!
I was about to and he's only gone and done it :cool:
AlexF
