| Home > Help Needed / General Tech Chat > new boost gauge | |||||||
35 Posts Member #: 883 Member Shillington, Pennsylvania, USA |
25th Apr, 2006 at 07:52:58pm
I got my new boost gauge installed and now it reads in the minus area all the time. I've taken the advice to plug up all the hoses that were open and the car seems to run fine but the boost gauge always reads on the minus side. What could be wrong? Slobo "Stick your foot in it" |
25th Apr, 2006 at 08:13:40pm
i hope you have fitted the gauge to the ""pressure"" side of the turbo
25th Apr, 2006 at 08:54:24pm
Have you done what i did and joined it ontop of the inlet after the one way valve? mine always read under 0 when i did that. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
1300 Posts Member #: 829 Post Whore essex |
25th Apr, 2006 at 09:07:02pm
You need to tap it in to the inlet maniford so the gauge reads on and off the boost 1293 Turbo mini
26th Apr, 2006 at 08:11:14am
Is it a Mocal one? I've had a faulty one myself. On 13th Jul, 2012 Ben H said:
26th Apr, 2006 at 01:45:34pm
Yes it is a Mocal one and I just plumbed it in exactly as the old one was. The old one always was in negative when idling but went to the plus side when going through the gears but this one never goes plus. But I did plug up two hoses that were open but went nowhere, The last one I plugged came out of the turbo right behind the carb on the drivers side(rhd) and went over toward the brake servo but not connected at the end to anything.Could that be the problem? Like I said, the car seems to run fine. "Stick your foot in it" |
26th Apr, 2006 at 01:51:40pm
When I fitted the old one back everything was fine...
26th Apr, 2006 at 02:12:35pm
Yep, mine's exactly like that except white face and I paid Avonbar 25 UK pounds for it. Wish I had thought of Ebay. Hopefully this is not too stupid of a question but which is the "pressure" side of the turbo? This is all new to me. "Stick your foot in it" |
26th Apr, 2006 at 02:14:24pm
I must add, Avonbar gave me some extra advice along with the gauge so to me it was worth the extra few dollars. Slobo "Stick your foot in it" |
26th Apr, 2006 at 03:18:31pm
When the engine is running at low revs, say 2000rpm with the throttle wide open, it is sucking air into the engine. Therefore it creates a vacuum. By connecting your gauge to the inlet manifold, you can see this vacuum (NEGATIVE pressure) at this time. When the revs get high enough and the turbo comes on boost, the engine is now having air FORCED into it under pressure. So say at 4000rpm at full throttle you should be able to see the gauge read POSITIVE pressure.
Edited by Tom Fenton on 26th Apr, 2006.
26th Apr, 2006 at 07:07:55pm
Ok, it looks like it is plumbed into the top front of the carb and the hose goes to a tee with one side going to the gauge and one side going to a vacuum thing on the distributor. Is that wrong? "Stick your foot in it" |
26th Apr, 2006 at 09:54:36pm
Yes it will work from the vac pipe off the carb 1293 Turbo mini
27th Apr, 2006 at 01:02:43am
So do you think it's a faulty gauge? And how about all these hoses that lead to nothing? Should they all be plugged up? Why have them just to plug them up? "Stick your foot in it" |
27th Apr, 2006 at 01:48:47am
i tried plubing my dump valve trigger into the vac advance pipe before and it wouldn't work as its the wrong side of the butterfly.
27th Apr, 2006 at 09:09:12pm
[quote=Tom Fenton,26/04/2006 15:18:31]
