Home > Technical Chat > Turbo 'out' pipe
Mike
Member #: 107
Sunny Sussex
not sure what its called, but its the pipe up from the compressor housing that would connect to the plenum..
anyways.. its a bit tight for space to get intercooler pipework off the top of it as the plenum's intercooler takeoff is just above it. A picture tells a thoudsand words....
and if i turn it 180 degs it has much more room but is this ok?
I'm not sure if its good to have sharp 90 degree bends in the intercooler pipes or not. Do you all use the standard pipe or have modded ones?
Kean
Member #: 341
aka T2clubby
South Staffs
Most people keep it in the standard posistion but cut it down and fit a 90 degree hose on Mike .
hth
Carl
Member #: 95
liverpool-on-sea
ive got HC racing moddified pipes well pleased with them there perfect cant post a pic no batts for camera, sorrry.
you may gain extra space buy making the pipes youve already got shorter?*smiley*
or find somewhere/ somebody that can weld aluminium and have the compressor pipe cut and welded at your desired angle
Edited by Carl on 25th Apr, 2006.
Mike
Member #: 107
Sunny Sussex
y carl, as much as i hate having to cut brand new stuff, i think cutting the plenum pipe back an inch or so is the way to go.
Are 90 deg bends a no-no? As in how much does it affect the flow?
jimmy
Member #: 829
essex
nice looking engine whats with the bolt at the top of the water pump ?
1293 Turbo mini
if its no bloody good, then brand new or not, get the hacksaw out!
turbo hogster
Member #: 178
stowmaket suffolk
ive got mine 180 deg around and works well with a 90 deg bend
I have mine like this but cut down a little. Seems ok.
Phil. *smiley*
On my T3 I made my oene out of a piece of 2" exhaust pipe and a bit of plate. ~It came out at 90 deg to that pointing towards the rad.
My T2 exit is a bit like that (position wise) and I have a 90 deg silicone pipe followed by a 45 deg to get it to the front.
As a rule of thumb I think you lose 1/2psi with each 90 deg bend.
Wil
Edited by wil_h on 26th Apr, 2006.
Dangerous
Member #: 417
Heres a hc racing modded one
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I spun mine 180 degrees like that mike and it didnt hit the bulkhead or anything (just to let you know)
