| Home > Help Needed / General Tech Chat > after something sticky... | |||||||
27th Apr, 2006 at 10:53:50am
I'm after some decent adhesive type stuff to stick a small magnet onto the outside of my brake drum. anyone got any recommendations?
Edited by Nick on 27th Apr, 2006. On 20th Oct, 2015 Tom Fenton said:
![]() 2102 Posts Member #: 432 Post Whore Swindon |
27th Apr, 2006 at 11:02:13am
no-nails?
27th Apr, 2006 at 11:04:40am
I'd stay stick with JB Weld (pun intended).
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
27th Apr, 2006 at 12:07:59pm
Bud666 what is this used for? |
27th Apr, 2006 at 12:12:32pm
speedo i think |
27th Apr, 2006 at 12:15:29pm
Id have thought that too but id have thought it would have gone around the driveshaft not the rear brake drum (saying that may have drums all around). |
27th Apr, 2006 at 12:33:34pm
Ive fitted my magnet on the pot joint, but anything over 50 mph and it starts counting down. I think its getting too many pulses per second because the pot is only small, need to put it on the drum for a bigger diameter......
27th Apr, 2006 at 12:39:33pm
get a magnet with a hole in and bolt it on(as found in a tollederal transformer
27th Apr, 2006 at 12:42:50pm
http://www.maplin.co.uk/Module.aspx?Module...riteria=ferrite
Edited by Dangerous on 27th Apr, 2006.
27th Apr, 2006 at 01:02:24pm
cool, looks like another trip to maplins may be in order.
27th Apr, 2006 at 01:06:41pm
I knew someone who stuck it on the inside of their wheel, could that not be an option instead? Also if you have minifins then you could possible drill a hole in a fin and do it that way. |
27th Apr, 2006 at 01:07:45pm
nah the inside of the wheels not really an option cos i've got 2 sets, one for winter and one for summer :) On 20th Oct, 2015 Tom Fenton said:
27th Apr, 2006 at 04:33:18pm
well have two magnets then. You seem to be loosing more of them any way.
831 Posts Member #: 908 Post Whore gateshead |
27th Apr, 2006 at 04:42:41pm
try getting some loctite 330. we use it at work to stick little vortex generators to the fin on tornado aircraft. if it can withstand 1500mph, it can stay on a drum! balls to the blower!!!
27th Apr, 2006 at 04:43:59pm
http://www.fwb.co.uk/mall/productpage.cfm/...up/018NPJ/63612 balls to the blower!!!
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
29th Apr, 2006 at 11:54:06am
Problem you got here is the temperature. The Loctite 330 is a thickened cyno based adhesive similar to "superglue" i think i remember. The Spray can is the activator. Its pretty good with heat but think this may be to much for it. I'd move your pickup.
1300 Posts Member #: 829 Post Whore essex |
29th Apr, 2006 at 12:08:30pm
What if you make a cap for the magnet and then tap that to the drum 1293 Turbo mini
30th Apr, 2006 at 08:51:57am
On 29/04/2006 11:54:06 Mirage said:
Problem you got here is the temperature. The Loctite 330 is a thickened cyno based adhesive similar to "superglue" i think i remember. The Spray can is the activator. Its pretty good with heat but think this may be to much for it. I'd move your pickup. Why does putting the pickup on a pot joint course more pulses per second than on a larger diameter ? both components are revolving at the same rpm. The only difference would be that the magnet on the larger diameter would move past the pickup more quickly. Thats pretty much what I meant, didnt word it correctly... Anyway it doesnt like it lol |
1st May, 2006 at 11:32:08am
hmmmm, not sure about that t2. where we use it, is directly in the reverse thrust path. when the buckets are deployed, they are directly in the hot exhaust gas. and thats going from freezing air temperatures to super hot in a short space of time. balls to the blower!!!
1st May, 2006 at 11:35:29am
i've got some very strong magnets that have a countersunk hole through them. offered them up for fitting in the bottom of the gearbox.
1st May, 2006 at 12:45:19pm
On 01/05/2006 11:32:08 superchargedstu said:
hmmmm, not sure about that t2. where we use it, is directly in the reverse thrust path. when the buckets are deployed, they are directly in the hot exhaust gas. and thats going from freezing air temperatures to super hot in a short space of time. I meant the bit about the pot joint not the glue temp lol. |
1st May, 2006 at 04:36:59pm
doh! ok. lol
