Home > General Chat > BP Ultinmate 102 (102 Octane Fuel)
http://www.whatcar.com/news-article.aspx?NA=219604
Want to run higher boost at avon? Pricy though
Id fill a jerry can with the stuff for that purpose only but the stations are all bloody miles away
Where do they think all the sports car drivers live FFS
Staggy
Member #: 947
New Zealand
just use avgas if you can get hold of it. Its leaded and has a minimum octane of 100. The stuff i am using is 105
Caution !!!! Slippery when boosting
Mike
Member #: 107
Sunny Sussex
ooh, one in portsmouth, still an hour away tho :(
colas
Member #: 102
Pennsylvania USA
I use Sunoco 110 Octane. Make one hell of a difference.
turbo hogster
Member #: 178
stowmaket suffolk
avgas is higher than 100 i think you are looking at least 110 to 120 depending AV number
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
avgas burns slowly too...
alex
AlexF
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
I best get down the AVCAT pump room and start filling jerry cans!
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
Staggy
Member #: 947
New Zealand
yes it is true that avgas burns slower. It is the same with all higher octane fuels. It also burns alot cleaner and smells so beautiful. if you can get hold of it military avgas has an octane rating of 135
if my car was rr'ed for regular pump gas, and i stuck some avgas in it would it run ok?
obviously i wouldnt get its full potential but would it do any damage?
Staggy
Member #: 947
New Zealand
It will be fine. Remember avgas is leaded tho. It will make your engine run cleaner, prevent detation, it burns slighty slower but contains more energy. It also makes you exhaust pipe a lovely grey colour and makes fuel leaks easy to spot due to the green dye in it.
In basic terms (which is as much as I know) the higher octane you have the more boost you can run.
So ,if you stick high octane fuel in any car and make no adjustments (and the ECU is limited in what it can adjust) then you'll see little differance. But the beauty of our turbo cars is that we can wind up the boost safely and make full use of the slower burn time.
Wil
turbochargedstu
Member #: 908
gateshead
hmm. i'm in the raf, and we have avgas at work, and i have slight pinking issues! need to do some networking i think!!!!!!!!!!!!!!!!!!
balls to the blower!!!
this has been coverd befor
click on the link and read away.............
it will put you in the ballpark for those of you who are new!
http://tetraboost.com/
Cheating buggers the lot of you. LOL!
I remember the days when guys drove to Avon, filled up with regular fuel, even had trolley jacks in the boot, and still took class D.
*tongue*
On 02/05/2006 00:56:24 mini1071s said:
Just remember that tetraboost, avgas etc with lead in it will destroy lambda sensors so remove them for race use with leaded :)
will it actually damage the lamba sensor, or just give inacurate readings?
pretty sure it overheats them and damages them for good.
Could be wrong!
I'm just going to use pump fuel, makes life easier!!
Staggy
Member #: 947
New Zealand
unfortunatly lead does affect your lamba sensor and also O2 sesnors. Otherwise i wold be running it all my cars. Its a bugger but you can't always win
yep - it 'coats' the sensor. Doesn't kill it immediately; and you could certainly tolerate it on a narrow-band, and just swap it out for a scrappy one...
But you don't want to run it on your expensive WB sensor...
barkiboi
Member #: 591
Rugeley, Midlands, England
Sounds a stupid question but where can you get avgas fuel from and will most places sell it to you tax free. e.g off road running like for the track and drag strip
