Home > Help Needed / General Tech Chat > Remote gearbox on A+
Hello
To save me cutting the floor on a new project, is it possible to fit a remote gearbox to a 1275a+ engine
im sure i read its possible if you use the a series idler and 3rd motion gear, but i cant find it anywhere
is this correct?
Yes, Easy. 3rd motion gear?? Just use some 4 sync A drops, and Jessica's your aunt!
icklemini
Member #: 745
Northampton
yep as above - you need all the a series drop gears (including the primary gear on the crank), and a series transfer case too.
TTFN,
Dave
ah goodo! thanks
do 998 fit 1275?
Dangerous
Member #: 417
do 998 fit 1275
No the crankshaft gear has a smaller I/D on it
balls
icklemini
Member #: 745
Northampton
the 998 primary gear is different to the 1275 primary gear...
TTFN,
Dave
But, when that is said. It's possible to open the 998 primary up to 1275 spec and fit the correct bush. However, I tried and the gear was so fucking hard that this is NOT a worhtwhile mod in my book.
Minispares sell new primarys for £60 I think
problem solved now, thanks all guys
but benross has been ultra generous and saved me meaasing around trying to mate the 2
