Home > Help Needed / General Tech Chat > Clutch Casing
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Hi, is the clutch housing on the metro turbo the same as a normal 1275 engine?
Thanks Chris
Nick
Member #: 154
Midlands
nope, the nose bearing race is a larger diameter.
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Cheers Mate!!
Nick
Member #: 154
Midlands
you can always put a non-turbo nose bearing on though and use a normal 1275 transfer case.
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Ive been told i can get the case repaired with a tig weld which ill have done cheers mate
