Home > 998cc > 998 primary gear bush
andeh
Member #: 97
Near Daventry, midlands
Not sure if this is going to be of any use or not.
Over the last couple of days i've spent time making up a bush for my friends 998 primary gear. Its the front one which is located near the engine and has been NLA for some time. I intially wanted to make up a floating one, but my first attempt ended up being duff and i didnt have time to redo it, but im confident i can do one if needed. I ended up just making an interfearance fit one, just like standard, which is going in his car today so can report back on sucsess etc.
If anyone is interested in this as a service i can make them up as needed for material cost + beer tokens. Worth noting that the material is not cheap at £30-£50 a foot, but obviously only priced up as part of that as you only need an inch or so to do the bush.
Edited by andeh on 7th May, 2006.
