Home > Help Needed / General Tech Chat > Carb vent valve and turbo boost solenoid
supermini
Member #: 187
hi,
I have a metro turbo engine ithout these 2 in subject and without the ECU.
what is for the carb valve? this is connected inthe SU and where else?
and the boost sollenoid? where is it connected?
Thank's
Carlos
Boost solenoid is an electronic bleed valve (can be replaced with a standard bleed valve, carb vet valve is the "anti run-on" valve which isn't really needed, it can be blocked off with a bolt.
Ecu controls the "electronic bleed valve" so can be ditched if not using it. :)
